muddy4x4xfar Posted April 3, 2010 Share Posted April 3, 2010 hi does anyone know what the shim thickness should be on a defender 1991 swivel housing. i havnt got the old ones so im having to set it up myself. does anyone know how to set it up if we cant find the thickness it should be? cheers everyone/ chris Quote Link to comment Share on other sites More sharing options...
western Posted April 3, 2010 Share Posted April 3, 2010 it's the pre-load you need to worry about not the shim thickness, just adjust the shims until the pre-load is correct, almost every vehicle will have a different size shim pack. Quote Link to comment Share on other sites More sharing options...
defender dinky Posted April 3, 2010 Share Posted April 3, 2010 hi does anyone know what the shim thickness should be on a defender 1991 swivel housing. i havnt got the old ones so im having to set it up myself. does anyone know how to set it up if we cant find the thickness it should be? cheers everyone/ chris hi, try this, http://www.fag.hiof.no/~frodehaa/swivelpinpreload.htm defender dinky Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 3, 2010 Share Posted April 3, 2010 I think it's .1, .25, .5, and .75mm. Mix and match them until the preload is set. Les. Quote Link to comment Share on other sites More sharing options...
