window
LR NUT
 Share
Hi
My Disco 2 drivers window is now struggling to go up and has to be aided up with my hand pushing the glass up while I hold the window switch! I did notice a while back the operation of the window was slowing down. Any ideas of what it could be?????
cheers
Whip the door trim off and check all the runners, and the window regulator/motor, my 300 started doing this, and found one arm had the little plastic slider missing and jumpped out of its trac, and twisted the metal work, and chewed up the gears on the motor. (New regulator for me)
worth giving the rubbers a squirt of WD that the window slide up and down in too, as this can free things up no end,
Ian ;)
 Share
