dad Posted April 4, 2010 Share Posted April 4, 2010 Hi I want to do a hand brake disc conversion is the X eng the only one or is there other option that I can make or buy. Quote Link to comment Share on other sites More sharing options...
western Posted April 4, 2010 Share Posted April 4, 2010 The X-eng is the only choice as far as I'm aware. here's how I fitted mine to my 110. http://forums.lr4x4.com/index.php?showtopic=10846 Quote Link to comment Share on other sites More sharing options...
dad Posted April 4, 2010 Author Share Posted April 4, 2010 Thanks for that looks an easy job to do Ian Quote Link to comment Share on other sites More sharing options...
western Posted April 4, 2010 Share Posted April 4, 2010 Some have fitted them in a couple of hours, I took my time as I was in no great rush. Quote Link to comment Share on other sites More sharing options...
jbs Posted April 4, 2010 Share Posted April 4, 2010 took a couple of hours to fit-bugger mine only took me about an hour tops Quote Link to comment Share on other sites More sharing options...
western Posted April 4, 2010 Share Posted April 4, 2010 took a couple of hours to fit-bugger mine only took me about an hour tops ^^^ not exactly what I typed I had to do a strip of the old drum brake first & was in no great hurry either. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted April 4, 2010 Share Posted April 4, 2010 Only took me about an hour too. But I have youth on my side.... *swift exit* Quote Link to comment Share on other sites More sharing options...
RTF Posted April 4, 2010 Share Posted April 4, 2010 Have to say the one on my 110 works well but then don`t intend to use off road But have one fitted to the 90 and is the PTO version which works brilant but did a wee modifaction to it before fitting welded a 1" thick plate between the 2 steel tubes spacers which the caliper fit`s to which when I though about it the tube spacers have a lot of pressure on them and not a lot of surface area to stop them from twisting sideways so the plate makes it more like a H shape so less stress on the to long bolts Not that there anything wrong with the design but if you think about it when at events and you want to winch someone out and on your own you pull on the handbrake so there is a lot of pressure on the 2 bolts which hold the calliper in place Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 5, 2010 Share Posted April 5, 2010 In the X-eng instructions it specifically says not to winch against it..... but yes I can see why you thought to do the above. I am fairly sure on a rangie/disco you would struggle to get it fitted with the extra metal you mention....? Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 5, 2010 Share Posted April 5, 2010 Only took me about an hour too. But I have youth on my side.... *swift exit* Something I no longer have What took you so long then Quote Link to comment Share on other sites More sharing options...
