Marks 110 Posted April 5, 2010 Share Posted April 5, 2010 About to bite the bullet and remove my engine in the next few days to sort out bent con-rod. I need to get hold of some non setting sealant to join the ladder frame back to the block when I put it back together. Its listed in the land rover manual as HYLOGRIP 2000. Anybody know who sells it? Cheers Mark Quote Link to comment Share on other sites More sharing options...
jbs Posted April 5, 2010 Share Posted April 5, 2010 RTV sealent perhaps? if so any good autofactors should have it in stock Quote Link to comment Share on other sites More sharing options...
western Posted April 5, 2010 Share Posted April 5, 2010 part number for Hylomar 2000 in my reply in this thread http://forums.lr4x4.com/index.php?showtopic=18478 Quote Link to comment Share on other sites More sharing options...
Marks 110 Posted April 5, 2010 Author Share Posted April 5, 2010 part number for Hylomar 2000 in my reply in this thread http://forums.lr4x4.com/index.php?showtopic=18478 Cheers for that. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 5, 2010 Share Posted April 5, 2010 I use threadlock or similar. You can use rtv, but you'll have to be quick assembling the parts as it skins quite quickly. Les. Quote Link to comment Share on other sites More sharing options...
Milemarker Type S Posted April 5, 2010 Share Posted April 5, 2010 I use the usual liquid/instant gasket sealant from motor factors- never had a problem with leaks. It gives you just enough time to assemble all the bits and then torque up before it skins. Quote Link to comment Share on other sites More sharing options...
fender1234 Posted April 6, 2010 Share Posted April 6, 2010 http://www.turnerengineering.co.uk/acatalog/info_212.html Quote Link to comment Share on other sites More sharing options...
Marks 110 Posted April 6, 2010 Author Share Posted April 6, 2010 http://www.turnerengineering.co.uk/acatalog/info_212.html Hi Have you actually used this? Just spoken to turners today but their engine builder is away so they couldn't confirm this is the stuff they use when they reassemble their engines. Need to be sure as if there is a leak between block and ladder frame it means taking engine out again to seperate them. Hylogrip 2000 is apparently very expensive but if its the best stuff I might get that. Cheers Mark Quote Link to comment Share on other sites More sharing options...
fender1234 Posted April 6, 2010 Share Posted April 6, 2010 No i didnt, i used RTV sealant on mine HTH Quote Link to comment Share on other sites More sharing options...
Marks 110 Posted April 6, 2010 Author Share Posted April 6, 2010 No i didnt, i used RTV sealant on mine HTH Yeah I have a tube of RTV and to be honest was thinking of using that. I guess you have to work pretty quickly before it sets? I presume yours has been OK then? Quote Link to comment Share on other sites More sharing options...
fender1234 Posted April 7, 2010 Share Posted April 7, 2010 Yeh i guess so, i didnt rush though just put it together fairly quickly, so far so good Quote Link to comment Share on other sites More sharing options...
Ex Member Posted April 7, 2010 Share Posted April 7, 2010 The problem with RTV (IMO) is that any excess gets squeeze out, hardens, breaks off and then these bits float around in the engine. Quote Link to comment Share on other sites More sharing options...
