highfellzippy Posted April 5, 2010 Share Posted April 5, 2010 MY TD4 went bang after fitting another turbo i later found out that the breather was blocked causing the car to run on oil only for 5 seconds though then it blew the intercooler [pipe off] still had plenty of oil so has not run dry now the car wont start turns over fine would running on oil clog the injectors / glow plugs so now the car wont start ??? HELP ! Quote Link to comment Share on other sites More sharing options...
EggNChips Posted April 9, 2010 Share Posted April 9, 2010 MY TD4 went bang after fitting another turbo i later found out that the breather was blocked causing the car to run on oil only for 5 seconds though then it blew the intercooler [pipe off] still had plenty of oil so has not run dry now the car wont start turns over fine would running on oil clog the injectors / glow plugs so now the car wont start ??? HELP ! No the injectors wouldn't be blocked as result of excessive back pressure and a TD4 should start even if the glowplugs weren't working. Probably the intercooler is blocked with oil. Quote Link to comment Share on other sites More sharing options...
