flatback90 Posted April 6, 2010 Share Posted April 6, 2010 i'm in the process of fitting the electronic td5 speedo to my 90 question is as i'm running a disco tramsfer box and 33" tyres which transducer will i need? my local supplier is sending me a defender one? is this correct? or is there something else i will need to get a correct reading or do i put up with it reading wrong?? thanks!! Quote Link to comment Share on other sites More sharing options...
fender1234 Posted April 6, 2010 Share Posted April 6, 2010 the transducer you get doesnt affect the reading its the speedo drive gear on the transfer box that needs to be right. Quote Link to comment Share on other sites More sharing options...
flatback90 Posted April 6, 2010 Author Share Posted April 6, 2010 the transducer you get doesnt affect the reading its the speedo drive gear on the transfer box that needs to be right. oooh ok so which drive gear do i need and how easy is it to change in situ??? Quote Link to comment Share on other sites More sharing options...
fender1234 Posted April 6, 2010 Share Posted April 6, 2010 http://forums.lr4x4.com/index.php?showtopic=2025 this should help Quote Link to comment Share on other sites More sharing options...
mickeyw Posted April 6, 2010 Share Posted April 6, 2010 The drive gear you need is the blue one FRC3310 with 20 teeth. I have just fitted one to mine and it reads spot on with 255/85s. Quote Link to comment Share on other sites More sharing options...
western Posted April 6, 2010 Share Posted April 6, 2010 The drive gear you need is the blue one FRC3310 with 20 teeth. I have just fitted one to mine and it reads spot on with 255/85s. Same as my 110 Quote Link to comment Share on other sites More sharing options...
flatback90 Posted April 6, 2010 Author Share Posted April 6, 2010 reading the thread in the link it would appear that the disco transfer box already has that one fitted?? Quote Link to comment Share on other sites More sharing options...
dantd5 Posted April 6, 2010 Share Posted April 6, 2010 Same as my 110 Sounds like Ralph's truck has different "intestines" V8 engine, disco t box, rangie gear box... de-cated tail rangie seats... and so on and so forth...... My truck is a 99 MY td5 and uses the green transducer...... Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted April 6, 2010 Share Posted April 6, 2010 Just to complicate things I used the green one to get a spot on reading with 255s Mo Quote Link to comment Share on other sites More sharing options...
dantd5 Posted April 6, 2010 Share Posted April 6, 2010 Holy mama..!! Sure means you do have a td5 t-box?? Quote Link to comment Share on other sites More sharing options...
western Posted April 6, 2010 Share Posted April 6, 2010 Sounds like Ralph's truck has different "intestines" V8 engine, disco t box, rangie gear box... de-cated tail rangie seats... and so on and so forth...... My truck is a 99 MY td5 and uses the green transducer...... No, I meant same speedo gear & tyre size Quote Link to comment Share on other sites More sharing options...
dantd5 Posted April 6, 2010 Share Posted April 6, 2010 No, I meant same speedo gear & tyre size I see.. Knew an adult will be around soon Quote Link to comment Share on other sites More sharing options...
flatback90 Posted April 6, 2010 Author Share Posted April 6, 2010 now i'm confused.... ihave a disco transfer box in already and you say i need a 20tooth and yet the link above says i have one in it already.... Quote Link to comment Share on other sites More sharing options...
mickeyw Posted April 6, 2010 Share Posted April 6, 2010 I just removed the green one. That worked about right with 265/75x16s (31.5" dia) Bigger tyres meant I need to change to the blue one. Quote Link to comment Share on other sites More sharing options...
western Posted April 6, 2010 Share Posted April 6, 2010 now i'm confused.... ihave a disco transfer box in already and you say i need a 20tooth and yet the link above says i have one in it already.... green are 21 tooth gears, refer to the link above to the speedo gear list I complied a while back. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted April 7, 2010 Share Posted April 7, 2010 Don't assume that you have a particular gear in your box just because of the transfer ratio being what it is, or that it came. You never know who's changed what is the past! Remove the transducer and prise out the gear with a small screwdriver, a very easy job with the box in the car; see what colour it is, count teeth etc, then make your calculated decision from there. Quote Link to comment Share on other sites More sharing options...
tomaco1 Posted May 3, 2011 Share Posted May 3, 2011 I have a TD5 speedo I was going to hook up to a 200tdi, my question is? Would it be easier to swap a new drive gear or just get a VDO speedo? I can get the VDO for $110 here in the US, and I figure by the time I find the right drive gear and swap it in, the VDO would be a better option. I just hooked up the VDO vision to my other truck and it was simple to install and set to get the exact speed. I run 285 75 16 and was wondering if its worth trying to get the right drive gear? Thanks Quote Link to comment Share on other sites More sharing options...
western Posted May 3, 2011 Share Posted May 3, 2011 I have a TD5 speedo I was going to hook up to a 200tdi, my question is? Would it be easier to swap a new drive gear or just get a VDO speedo? I can get the VDO for $110 here in the US, and I figure by the time I find the right drive gear and swap it in, the VDO would be a better option. I just hooked up the VDO vision to my other truck and it was simple to install and set to get the exact speed. I run 285 75 16 and was wondering if its worth trying to get the right drive gear? Thanks IIRC the VDO speedo can be user calibrated to sit the tyre size. Quote Link to comment Share on other sites More sharing options...
Tdi-Mike Posted July 24, 2011 Share Posted July 24, 2011 Any help please....I have re-built a Defender with 1/4 Lt230, R380 box. It is a 300 Tdi with the newer factory Td5 harness made for the 300. The problem I am having is the spedo, new, is reading about twice what it should be. I have installed the YBE100530 transducer and the blue gear. I do not know what else to look for? I was thinking I might have been sent the wrong transducer but?... Thanks Quote Link to comment Share on other sites More sharing options...
western Posted July 24, 2011 Share Posted July 24, 2011 Any help please....I have re-built a Defender with 1/4 Lt230, R380 box. It is a 300 Tdi with the newer factory Td5 harness made for the 300. The problem I am having is the spedo, new, is reading about twice what it should be. I have installed the YBE100530 transducer and the blue gear. I do not know what else to look for? I was thinking I might have been sent the wrong transducer but?... Thanks what size tyres are you running ?? the fFRC3310 blue 20tooth [standard fit in 110] should work fine with 7.50 or 235 or 255 tyres. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted July 24, 2011 Share Posted July 24, 2011 Any help please....I have re-built a Defender with 1/4 Lt230, R380 box. It is a 300 Tdi with the newer factory Td5 harness made for the 300. The problem I am having is the spedo, new, is reading about twice what it should be. I have installed the YBE100530 transducer and the blue gear. I do not know what else to look for? I was thinking I might have been sent the wrong transducer but?... Thanks What brand was the transducer? There have been a number of reports on here recently of the Britpart ones double reading, most recent occurrence was NickWilliams, once he changed to a genuine transducer it read perfectly. I would suspect that double reading was a non genuine transducer rather than an incorrect gear as whilst the wrong gear would lead to an incorrect reading it wouldn't be as much as double given the range of gears available.... hth Quote Link to comment Share on other sites More sharing options...
crclifford Posted July 24, 2011 Share Posted July 24, 2011 What brand was the transducer? There have been a number of reports on here recently of the Britpart ones double reading, most recent occurrence was NickWilliams, once he changed to a genuine transducer it read perfectly. I would suspect that double reading was a non genuine transducer rather than an incorrect gear as whilst the wrong gear would lead to an incorrect reading it wouldn't be as much as double given the range of gears available.... hth ^^^^^ what he said...i had a problem with my Br*tpart one reading double..so switched to a genuine one and it read correctly. Quote Link to comment Share on other sites More sharing options...
Tdi-Mike Posted July 25, 2011 Share Posted July 25, 2011 Just running 265/75-16 tires. I might expect a little difference but not that much. I have looked on line and the transducers are green and mine is black. I checked the box and it does say YBE100630. Do you think I may have gotten the wrong part? I also checked the wiring loom and all seems correct. Quote Link to comment Share on other sites More sharing options...
Tdi-Mike Posted July 25, 2011 Share Posted July 25, 2011 I got mine from Brookwells a bit ago and think it was a lesser expensive one. It is in a generic box so I know it is not a LR OE part. I will source another one and check it out. I will post up as soon as I get it and tell everybody what happens. Thanks for your help Quote Link to comment Share on other sites More sharing options...
mickeyw Posted July 25, 2011 Share Posted July 25, 2011 From what I have heard of late, the black ones are of different construction to the genuine item, and are not worth entertaining. The green one is what you need. The part number should be YBE100530 not YBE100630. See here. Quote Link to comment Share on other sites More sharing options...
