94softdash Posted April 6, 2010 Share Posted April 6, 2010 Hi all, I'm new to the forum and need a little help. I've got a '94 Rangie Classic softdash wich has recently started drinking a lot more fuel so I tried to plug my fault code reader in and encountered a problem, the ecu isn't under the passenger seat where I expected it to be. The ABS ecu is under the passenger seat and under the driver's seat is nothing at all except the wiring for the electric seats I haven't got. I've dropped the panel under the steering wheel and checked around the fusebox with no luck same with the engine bay. Anyone got any ideas, before I take the car completly to bits? Cheers. Quote Link to comment Share on other sites More sharing options...
MikeAK Posted April 6, 2010 Share Posted April 6, 2010 Hi, From what I remember on the softdash it moved to behind the trim panel under the dash immediately forward of the drivers door. Regards Mike Quote Link to comment Share on other sites More sharing options...
MikeAK Posted April 6, 2010 Share Posted April 6, 2010 Found a picture in RAVE Mike Quote Link to comment Share on other sites More sharing options...
94softdash Posted April 7, 2010 Author Share Posted April 7, 2010 Cheers for that, I'll check it out as soon as I can. Quote Link to comment Share on other sites More sharing options...
94softdash Posted April 8, 2010 Author Share Posted April 8, 2010 You were dead on Mike, found the ecu just where you said, couldn't find the square black diagnostic plug though. I'll have a better look tommorrow. Cheers again. Quote Link to comment Share on other sites More sharing options...
vougese39 Posted April 11, 2010 Share Posted April 11, 2010 plug is white 5 pin and under the dash pannel not many fault readers can read the classic ecu Quote Link to comment Share on other sites More sharing options...
