welling4x4 Posted April 7, 2010 Share Posted April 7, 2010 Hi Pepe's Can any 1 HELP. my range rover has started to swerve to the left side very badly when I need to brake hard. the front goes to the left & the rear end goes as well & I do not know how to cure it. So if any 1 has any clues or ideas to cure this fault I would be very Grateful. Quote Link to comment Share on other sites More sharing options...
Dengie Boy Posted April 7, 2010 Share Posted April 7, 2010 Sounds like the brake calipers are not working correctly on the offside. The pistons in the calipers need to move freely to work correctly, if they dont then they possibly need rebuilding. You can purchase brake caliper rebuild kits from any landrover retailer. Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted April 7, 2010 Share Posted April 7, 2010 Time to crawl underneath and have a good look around! Have you checked the obvious and easy stuff, e.g. plenty of tread on tyres (and similar tyres with similar tread depth on all corners), tyre pressures all correct? Then: - any brake calipers seized (on or off)? Worn out brake pads? - all dampers okay? - all springs okay (none broken, for instance) - any broken suspension components? - worn suspension bushes? Finally - if you still can't identify the cause yourself, get it to a garage as soon as because it's not safe to drive (doesn't sound like you need telling that!). My money's on a seized brake caliper, if it's only braking that has any ill effects Quote Link to comment Share on other sites More sharing options...
welling4x4 Posted April 7, 2010 Author Share Posted April 7, 2010 Thank U all. I will have a check on the calipers Hopeffully it will be some thing simpel ( I hope) Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted April 7, 2010 Share Posted April 7, 2010 A word of warning - if you do buy a caliper rebuild kit don't buy Britpart - half the bits are the wrong size. I'm not sure about other pattern brands, of even if there are any. I've given up rebuilding calipers now and just get a complete recon caliper, but I'm not on quite as tight a budget as I was (well, I wasn't before the new engine... ). Quote Link to comment Share on other sites More sharing options...
welling4x4 Posted April 9, 2010 Author Share Posted April 9, 2010 A word of warning - if you do buy a caliper rebuild kit don't buy Britpart - half the bits are the wrong size. I'm not sure about other pattern brands, of even if there are any. I've given up rebuilding calipers now and just get a complete recon caliper, but I'm not on quite as tight a budget as I was (well, I wasn't before the new engine... ). freely Thank you all. The fault was a seized cailiper & the pistons were NOT able to move yet alone freely & yes I did buy a britpart rebuild kit & yes your right the don't fit the outer end seals snap get bent or just DO NOT work. (What a waste of money & time & effort) any 1 going down this route of the rebuild kit Trust me it's rubbish & as I said a waste of money time & efffort. (Britpart you need to try them out for ur selfs) Quote Link to comment Share on other sites More sharing options...
squaddiefox Posted April 9, 2010 Share Posted April 9, 2010 i had this with a couple of britpart seal kits. i took them back and got them changed as i didn't try and fit them. checked the new ones and they were right. i think it is all about pot luck with britpart. Quote Link to comment Share on other sites More sharing options...
welling4x4 Posted April 9, 2010 Author Share Posted April 9, 2010 I tried 3 packets of these Britpart seal kits & they were all the wrong size.Sent them back got me money back & now hopefully get a pair of Brake calipers @ sodbury PLease, PLease, Quote Link to comment Share on other sites More sharing options...
