Andrew Chua Posted April 8, 2010 Share Posted April 8, 2010 Hi all, I've a strange problem and it's as above. the R380 box sometimes blocks me from shifting into 2 directly from 1 or neutral. say when i'm moving off from a stop, from 1 to 2 and it doesn' want me to go into 2. mind you, i don't rev hard on gear 1 some i'm sure i'm at a reasonable speed which gear 2 will be usable. i've got a 1.222 disco t-box fitted though. other times, it's when i'm at a stop and i try to put it to 2, it won't allow me to do so until i release the clutch and try again. Sometimes on a bad day, it grinds when it drops into 2. on a good day, it all works well. any ideas before i migh have to do something drastic like overhaul the box? Andrew Quote Link to comment Share on other sites More sharing options...
western Posted April 8, 2010 Share Posted April 8, 2010 When was the gearbox fluid last replaced, you could try Difflocks EVO1 gearbox fluid http://shop.difflock.com/difflock-evolution-fully-synthetic-gear-litre-p-51.html Quote Link to comment Share on other sites More sharing options...
landy andy. Posted April 8, 2010 Share Posted April 8, 2010 Mine was the same till Difflock Evo oil. It then gets better with a few miles. Andy Quote Link to comment Share on other sites More sharing options...
Andrew Chua Posted April 9, 2010 Author Share Posted April 9, 2010 ok sounds worth a try. i'll order some and hopefully they ship down to singapore. Thanks! Quote Link to comment Share on other sites More sharing options...
lardy Posted April 10, 2010 Share Posted April 10, 2010 Andrew i would be of the mind set to drop the gaer oil for fresh and see what you have after that. We have the that aussie oil enricher over here in Australia (west) it leaves a residual film on the gears (b/goxes, transfer cases, difs) so that the gears are always primed with oil. If you have any drama's getting the stuff the other guys have recommenede give me a hoy i'll give you the details of the stuff we have here. Regards. Quote Link to comment Share on other sites More sharing options...
