disco chassis
dicsosfa
hi :)
having found that my chassis has a few more holes than it should :( , i have 2 questions 1, is there any wiring in the chassis (in case when i come to weld it)
2,if i was to get another chassis how hard is it to change ie can the body be lifted off whole ( i have access to a telehandler)
its a m reg 300tdi
Roy
no wiring in chassis afaik, mine needed to have a crossmember replaced, the one that the rear seat belts attach to and some plates but once you get started it soon comes together, loads easier than a chassis swap.
if you get another chassis just cut off the bits you need for yours and weld them in.
