V8david Posted April 9, 2010 Share Posted April 9, 2010 Hi, 1989 RR 3.5 My fantastic 1989 alarm immobiliser is linked to the central locking (obviously), normal routine is the indicators flash 3 times when I unlock, which gives me 10 seconds max to start her before the immobilser kicks in. When I switch off, get out and lock up the indicators stay on (not flashing) for about 3 seconds before going off. Latetly though the indicators have been staying on (not flashing, just on) after either operation. They go off eventually if I lock and unlock a few times but it's getting worse/more frequent. I couldn't even override them with the hazard switch. Question is where should I start looking? Is it a fault with the indicator relay? That's my first thought as the immobiliser still works in relation to the central locking, I can still start the engine and drive off with all the indicators on. Don't want to be locking/unlocking too much as I've heard about burning out the central locking control unit. Cheers Dave Quote Link to comment Share on other sites More sharing options...
squaddiefox Posted April 9, 2010 Share Posted April 9, 2010 i had this on mine but not with the central locking, its a two door and doesn't have it. my indicator relay was knackered (didn't realise until i found out why the indicators were staying on and not flashing) and it burnt out the wiring on my hazard switch. check all the wiring and connections. i changed the relay and all was fine. Quote Link to comment Share on other sites More sharing options...
