Disco LT77 into a Defender
Hi All
I've read various forums and they say that you cannt put a disco g/box in a defender without modifying the tunnel/seatbox..
I assume this is using the complete disco box including selector(lever) housing
Is it possible to swap the selector housings therefore moving the gear lever further forwards ?
Cheers Jon
If you put the disco box on, the gearsticks will be the wrong way round and further back, so it'll be awkward to change gear/select Hi/Lo. The rear housing of the gearbox has to be swapped over for the Defender item, which is not exactly a DIY job. I think you had to swap bell housing as well.
Les.
 Share
