PaddyZulu Posted April 10, 2010 Share Posted April 10, 2010 Someone previously has written off the plug on my gearbox, even to the point of attempting to chisel it off ! Would anyone know where I can get one, as its going to be a mess if and when I get it out. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 11, 2010 Share Posted April 11, 2010 Drain plug is part No FRC6145, and sealing washer is part No FTC4112. You should be able to get these from the usual L/R parts suppliers. Les. Quote Link to comment Share on other sites More sharing options...
PaddyZulu Posted April 11, 2010 Author Share Posted April 11, 2010 Drain plug is part No FRC6145, and sealing washer is part No FTC4112. You should be able to get these from the usual L/R parts suppliers. Les. Thank you for the timely and comprehensive reply with numbers too Les, I had looked in my Rimmer catalogue and online to no avail. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 11, 2010 Share Posted April 11, 2010 http://www.johncraddockltd.co.uk/productnos_search.asp?partno=FRC6145 http://www.lrseries.com/shop/product/listing/6555/FRC6145-DRAIN-PLUG-MAGNETIC.html?search=FRC6145&page=1 Les Quote Link to comment Share on other sites More sharing options...
PaddyZulu Posted April 11, 2010 Author Share Posted April 11, 2010 Thanks again for the info, its just occurred to me though that its the fill plug I need that needs a T55 Torx to remove it. At least I can search the links you advised to find it. Cheers Quote Link to comment Share on other sites More sharing options...
PaddyZulu Posted April 11, 2010 Author Share Posted April 11, 2010 Thanks again for the info, its just occurred to me though that its the fill plug I need that needs a T55 Torx to remove it. At least I can search the links you advised to find it. Cheers Found it and blow me down Rimmer has it, just got to work out a plan to get the old one out now ! http://www.rimmerbros.co.uk/Item--i-FTC4056 Quote Link to comment Share on other sites More sharing options...
