td5 power steering
Have a 2005 td5 Def. is gone now 123000 km. lately I have had problems with power steering. when I turn it seems that the power steering not working properly. when I turn the switch on and off (wheat not know how to explain it in English). it will have and so normal. this happens all the time when I turn the steering wheel. has aired servo pump. anyone here an idea of what it can be.
If the steering feels lumpy or stiff check the PAS Drive belt tension is correct & the jints on the steering column are free & lubricated, also all the hoses connections are tight & not puling air into the system or letting PAS fluid leak out.
 Share
