lansalot Posted April 12, 2010 Share Posted April 12, 2010 Hi Am going to be swapping my tired 3.5 for a fresh(er) 3.9. The 3.9 came from an auto range rover, so as the Defender is a manual I'm going to stick with that for the time being. Looking for some info - and part numbers - on what all I need to refresh to hook up ? Gearbox is LT85 if I remember right, and of course I'll have everything necessary on the existing kit. Naturally tho I'll be replacing the clutch while I'm at it (and I think the release bearing)? Does anyone have part numbers/links for these consumables, and anything else worth doing while I'm in that end of things ? Also, for fitting the clutch plate, any information on torque settings for bolts, whether thread-lock is needed, anything along those lines ? Thanks A Quote Link to comment Share on other sites More sharing options...
lansalot Posted April 18, 2010 Author Share Posted April 18, 2010 Anyone ? Quote Link to comment Share on other sites More sharing options...
western Posted April 18, 2010 Share Posted April 18, 2010 what you need is the manuals & parts book links at the top of the request for part numbers forum, they will let you sort out any numbers & info on swapping the bits over Quote Link to comment Share on other sites More sharing options...
lansalot Posted April 18, 2010 Author Share Posted April 18, 2010 OK, might be back for more info on exactly what's needed - thank for that :-) A Quote Link to comment Share on other sites More sharing options...
