ajh Posted April 12, 2010 Share Posted April 12, 2010 Can anyone offer advice on an 03 D2 as to what what would be the most likely cause for start then stall after wading (well, a bit more vigorous that just wading in this case) so that I can track down the culprit and seal it up properly. Quote Link to comment Share on other sites More sharing options...
Wolfie69 Posted April 12, 2010 Share Posted April 12, 2010 Just had a similar problem with mine and I had to remove the ECU,take off front and back covers(undo 4 screws 1 in each corner and prise gently open with a screw driver)then I left it on my boiler for 2 days,refit and I was away again.Hope this helps Quote Link to comment Share on other sites More sharing options...
ajh Posted April 12, 2010 Author Share Posted April 12, 2010 If the ECU is inside the vehicle, how does it manage to get wet inside? Quote Link to comment Share on other sites More sharing options...
ches Posted April 12, 2010 Share Posted April 12, 2010 the ecu is in the engine bay between the battery and the jack. Quote Link to comment Share on other sites More sharing options...
ajh Posted April 12, 2010 Author Share Posted April 12, 2010 Does the battery box have to come out first to get to it? Quote Link to comment Share on other sites More sharing options...
Wolfie69 Posted April 12, 2010 Share Posted April 12, 2010 the ECU is the silver box about 8 inches square by 2 inches thick with black and red electrical plugs located behind the battery box in the same compartment as the jack. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 12, 2010 Share Posted April 12, 2010 Does the battery box have to come out first to get to it? No. Take out the jack, and I think there is just 1 self tapping screw to remove and you can slide it up and out. Take the battery off first. Quote Link to comment Share on other sites More sharing options...
ajh Posted April 13, 2010 Author Share Posted April 13, 2010 Hmm, would liquid water drops hitting the MAF have a similar outcome? Quote Link to comment Share on other sites More sharing options...
ajh Posted April 13, 2010 Author Share Posted April 13, 2010 Well, battery is out, battery box is out, coolant header tank is off, and unless it is built into the fusebox this D2 has no ECU in that location. Quote Link to comment Share on other sites More sharing options...
ajh Posted April 13, 2010 Author Share Posted April 13, 2010 So, yes, apparently this is the case. It was a small amount of water that got into the ball on the air intake. Quote Link to comment Share on other sites More sharing options...
