Chris Davies Posted April 13, 2010 Share Posted April 13, 2010 Hi, could anyone tell me the part number for the correct oil temp sender. Engine is defender 200tdi, the guage I believe came out of a 2.5 NAD. Thanks Chris Quote Link to comment Share on other sites More sharing options...
western Posted April 13, 2010 Share Posted April 13, 2010 Photo's & parts diagram here in my photobucket pages got oil temp & pressure gauges/senders on my 200tdi Quote Link to comment Share on other sites More sharing options...
Chris Davies Posted April 14, 2010 Author Share Posted April 14, 2010 Thanks for that Ralph, just what I needed The list of new parts on your diagram are for oil temp and pressure - correct? Am I correct in assuming that ETC4033,4034 and 4043 are for pressure and only PRC4372 is needed for oil temp? Hope this is the case as Craddocks stock PRC4372 but none of the others. On their website it is listed as . . TRANSMITTER OIL TEMPRETURE 90/110 2.5 DIESEL N/A & TURBO I assume also ok on a 200tdi? Thanks Chris Quote Link to comment Share on other sites More sharing options...
western Posted April 14, 2010 Share Posted April 14, 2010 All the hand drawn parts & hand written part numbers are for the oil temp & oil pressure items, you'll need to source a selection of copper washers [halfords do boxed selection] the subject parts are common to all the 4 cylinder engines But not 300Tdi, so Yes they'll fit a 200Tdi because thats what I've done. PRC4372 is the oil Temp sender & it needs a suitable copper washer. all the other parts are for oil pressure sender. remove the existing oil pressure warning light switch, screw it into end of ETC4033,the banjo fits on the other end nearest oil filter 7 the large preesure sender fit the banjo threaded end. Quote Link to comment Share on other sites More sharing options...
Chris Davies Posted April 14, 2010 Author Share Posted April 14, 2010 Thanks again for clarification, just oil temp for now, but pressure would be good sometime in the future. Cheers Chris Quote Link to comment Share on other sites More sharing options...
western Posted April 14, 2010 Share Posted April 14, 2010 I fitted the LR genuine gauges to a dash top 4 gauge pod, oil pressure on right/oil temp/2 x VDO Vision voltmeter, pod came from Europa Spares. Quote Link to comment Share on other sites More sharing options...
