LR NUT Posted April 14, 2010 Share Posted April 14, 2010 Hi everyone, MY TD5 (04/05) has seemend to have developed a squeaking noise coming from the rear passanger side wheel. The noise is sometimes heard at a low speed (6mph) or even whilst town driving. However whilst towing the noise seems to get a bit louder and again occurs mostly at the same speeds and when turning left or right! (The squeaking is never constantly heard) any ideas what to check cheers Quote Link to comment Share on other sites More sharing options...
kingdong2 Posted April 14, 2010 Share Posted April 14, 2010 Hi LR NUT i would jack the rear of the car up and check for play in the rear wheel bearings or take it to your landy man to get it checked out, it could be noisy brakes but with you saying it goes away when you turn a corner tells me its wheel bearing related. graham _________________ 03 d2 td5 auto e.s. 97 d1 300 tdi man. Quote Link to comment Share on other sites More sharing options...
LR NUT Posted April 14, 2010 Author Share Posted April 14, 2010 Hi LR NUT i would jack the rear of the car up and check for play in the rear wheel bearings or take it to your landy man to get it checked out, it could be noisy brakes but with you saying it goes away when you turn a corner tells me its wheel bearing related. graham _________________ 03 d2 td5 auto e.s. 97 d1 300 tdi man. Hi kingdong2 sorry maybe my post wasnt clear but the noise is more evident when turning with a trailer, Also I will be checking the wheel for play when I return from work today, as was going to do it last night but the weather was horrible cheers Quote Link to comment Share on other sites More sharing options...
axlechorus Posted April 14, 2010 Share Posted April 14, 2010 Sounds like a bearing. I had the same on the back of my discovery, found it was the bearings that had gone loose. Hope this helps. Ryck Quote Link to comment Share on other sites More sharing options...
LR NUT Posted April 14, 2010 Author Share Posted April 14, 2010 I have had the disco on the jack and there is no play in the wheel. When rotating the wheel it also felt fine and there was not any squeaking. What next ?? Quote Link to comment Share on other sites More sharing options...
milliejasper1111 Posted April 15, 2010 Share Posted April 15, 2010 Still worth pulling the hub off, mine was noisy, zero play in the bearing, everything felt fine, but i looked and the bearing was in 3 peices Ian Quote Link to comment Share on other sites More sharing options...
paddyboy Posted April 16, 2010 Share Posted April 16, 2010 Still worth pulling the hub off, mine was noisy, zero play in the bearing, everything felt fine, but i looked and the bearing was in 3 peices Ian can you change the bearing or do you need to get the new hub Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 16, 2010 Share Posted April 16, 2010 Whole hub I'm afraid - and a bit expensive, so make sure that's the problem. Les. Quote Link to comment Share on other sites More sharing options...
LR NUT Posted April 18, 2010 Author Share Posted April 18, 2010 Hi everyone, MY TD5 (04/05) has seemend to have developed a squeaking noise coming from the rear passanger side wheel. The noise is sometimes heard at a low speed (6mph) or even whilst town driving. However whilst towing the noise seems to get a bit louder and again occurs mostly at the same speeds and when turning left or right! (The squeaking is never constantly heard) any ideas what to check cheers Hi Guys Jacked up the disco this morning and had the wheel off. After spinning the wheel every rotation at a centre point I could here the squeaking / rubbing noise coming from the handbrake drum plate located centre of the vehicle. Does anyone else have this problem and is it a normal occurance? (Originally I thought the noise was coming from the rear wheel when driving the car, but its not the wheel)I have attached a pic of where the noise is coming from. cheers LR NUT Quote Link to comment Share on other sites More sharing options...
bear Posted April 18, 2010 Share Posted April 18, 2010 Hi LR Nut, I have a 200tdi and there is never a noise you describe. I suspect there's something wrong with your handbrake shoes or some muck in the drum. Quote Link to comment Share on other sites More sharing options...
paddyboy Posted April 19, 2010 Share Posted April 19, 2010 Whole hub I'm afraid - and a bit expensive, so make sure that's the problem. Les. am goen to cry both wheel bearings gone in mine Quote Link to comment Share on other sites More sharing options...
