paul mc Posted April 14, 2010 Share Posted April 14, 2010 Hi, i have an air leak in the fuel system somewhere on my 1987 3.5 V8 EFi, if i block the air inlet in front of the air filter the engine slows right down and nearly stalls but not quite, surely if i completely block the air inlet it should cut out? I am looking for a diagram showing which vacuum pipes should go where as during the rebuild i may well have mixed up a couple, there is one loose which i have blocked off which used to run to the heater matrix, but as i took it out i just blocked the pipe. I thought i saw a diagram in the RAVE manual but have just looked through it and can't find it now. Any help much appreicated. Quote Link to comment Share on other sites More sharing options...
SteveRK Posted April 14, 2010 Share Posted April 14, 2010 The crankcase breather pipes that connect to the inlet plenum chamber will be enabling the engine to continue to run i suspect. mines hot-wire so likely to be different but your connections will include: fuel pressure regulator connecting to rear of plenum chamber idle speed stepper motor link pipe from rear of plenum to air intake adjacent throttle butterfly brake servo take off at plenum chamber heating system vacuum reservoir at plenum chamber to n/S inner wing spherical plastic object Crankcase breather from O/S rocker cover to T piece that connects to plenum ch' & throttle housing Distributor vacuum advance to throttle housing Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 14, 2010 Share Posted April 14, 2010 Depends how you're blocking it really, engines idle with the throttle closed and a minuscule amount of air passing the throttle plate, so unless you've done a bang up job of sealing your airbox (including the drain holes etc.) and blocking the end I don't think it's that surprising. Quote Link to comment Share on other sites More sharing options...
