def130 Posted April 15, 2010 Share Posted April 15, 2010 Hi all I'm a newbie, so please go easy with me I’m the proud owner of a 130 Station Wagon with a 300tdi engine transformed by Foley’s, I’m asking for some information regarding a PTO Winch, does anyone have one for sale or know here I can find one? Have saw a few on Ebay but they are or for series or TD5, I have been told the TD5 don’t fit because of the different gear box location, can someone please let me know if is possible fir one from a series? Thanks in advance for any advise. Quote Link to comment Share on other sites More sharing options...
def130 Posted April 16, 2010 Author Share Posted April 16, 2010 Hi all Found this one on Ebay item 170473418877 Can someone please let me know if this will fit a 130 300tdi Thanks in advance for any reply Quote Link to comment Share on other sites More sharing options...
western Posted April 16, 2010 Share Posted April 16, 2010 it's a 525 mechanical PTO driven winch so it should fit. Quote Link to comment Share on other sites More sharing options...
def130 Posted April 16, 2010 Author Share Posted April 16, 2010 it's a 525 mechanical PTO driven winch so it should fit. Thanks for the reply, Western Can someone please let me know what is a fair price for one of those Thanks in advance Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 16, 2010 Share Posted April 16, 2010 Absolute maximum £500, more like £250. Quote Link to comment Share on other sites More sharing options...
def130 Posted April 22, 2010 Author Share Posted April 22, 2010 Hi again Manage to find another PTO winch only 100 yards from my house The owner doesn’t know/ remember from what Defender that had come from, because was a old friend that had give him the pto, during the time he had a 110 300tdi but he never try to fit it. So I have manage a good deal After giving a good look (already in my garage) to try to find any ref on the PTO or winch I have found Winch - Serial No 525/*550 PTO – is marked 6440/525 by hand and the casing number is 5407 My question is can someone please let me know if will fit my 300tdi, pictures are welcome too Thanks in advance for any help Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 22, 2010 Share Posted April 22, 2010 Posting up some pics would help Quote Link to comment Share on other sites More sharing options...
def130 Posted April 25, 2010 Author Share Posted April 25, 2010 some pictures from my winch, can someone please identify this please Do you think this will fit my 300 tdi Thanks for any help in advance Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 26, 2010 Share Posted April 26, 2010 Yes. Have a search for posts on clocking the PTO round so it doesn't hang down and get snapped off. Quote Link to comment Share on other sites More sharing options...
def130 Posted April 26, 2010 Author Share Posted April 26, 2010 Hi again After spend some time looking with more time to the winch find that I will need a new cable before fit it to the LR, so after remove the roller fairlead (and find that one of the bolts was broken another think to solve later) find this situation Now I have a question. Should the drum rotate easy? If not how can I engage the Winch? Have a leak from this place and a broken mount. From the manual I will need to remove the Allen screw (that I manage to do) and after that the black plastic cap how???? Just call Superwinch and they don’t have any spares parts, does anyone know where to find parts? Can someone recomend any place around Coventry Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 26, 2010 Share Posted April 26, 2010 The first picture is the dog clutch which engages the winch or allows it to freespool, in your picture the winch is in freespool so should turn easily. Sliding the two parts together engages the drive. Spare parts wise, there are only about 3 moving parts and they don't really go wrong, so aside from seals/bearings/nuts/bolts (all available from industrial suppliers) there's not really anything else to it. You're best off having a search, starting with the tech archive, as I'm sure this setup has been covered in great detail before, probably by Nige (hybrid_from_hell). Quote Link to comment Share on other sites More sharing options...
def130 Posted April 26, 2010 Author Share Posted April 26, 2010 The situation is I can't make the connection, Do you think I need to find someone with a press machine and have the drum removed from the shaft? Or assembly the winch and try to release the drum when making the test? Sorry be so upsetting but I don’t want make any mistakes / damage Thanks in advance Quote Link to comment Share on other sites More sharing options...
steve b Posted April 26, 2010 Share Posted April 26, 2010 You could use a puller to draw the dog clutch off the shaft and then the drum , if its stuck tight it may be worth soaking it in a bucket of diesel for a few days first cheers Steveb Quote Link to comment Share on other sites More sharing options...
def130 Posted April 26, 2010 Author Share Posted April 26, 2010 Thanks for all advise I can remove the dog clutch 5 by and hand. drum 14 and drum shaft 16 don’t move so I have spray some WD40, but I will put this in diesel as advised Have already someone change the bearing 40? Leaking heavily what is the way to remove cap 35 Thanks in advance Quote Link to comment Share on other sites More sharing options...
def130 Posted April 28, 2010 Author Share Posted April 28, 2010 Manage to separate the drum from the shaft with a hydraulic puller (fantastic piece of kit) that I already put on my list of tools to buy After a good clean and some sand paper the drum rolls as it should. Now I have a question should I put any kind of grease like copper grease between the shaft and drum or something like I already read somewhere on the forum the "one-shot " Superwinch have send a manual for my Winch and PTO, could someone from admin add this on http://forums.lr4x4.com/index.php?showtopic=16479 Is for a 525 and a 6440 PTO Land Rover 525 Kit 6440.pdf Thanks in advance for any advise Quote Link to comment Share on other sites More sharing options...
def130 Posted April 30, 2010 Author Share Posted April 30, 2010 Now I have a question should I put any kind of grease like copper grease between the shaft and drum or something like I already read somewhere on the forum the "one-shot " Please some advise, i'm trying to assembly the winch over this long weekend Thanks Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 30, 2010 Share Posted April 30, 2010 No harm in greasing it during assembly, normal grease should be fine. Copper grease is more of an anti-seize compound for fasteners, one-shot is more liquid and would probably run out. Quote Link to comment Share on other sites More sharing options...
def130 Posted April 30, 2010 Author Share Posted April 30, 2010 thanks, i will use normal grease Quote Link to comment Share on other sites More sharing options...
