disco tom Posted April 16, 2010 Share Posted April 16, 2010 hi i am in need of some advice i have 200 tdi disco that isnt starting i can prime and get fuel to the injection pump but nothing out the injector pipe end of the pump, i have tried and tested the stop solenoid thats all ok, fuel is going into the pump but nothing coming out any help will be much appreciated thanks Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 16, 2010 Share Posted April 16, 2010 Was the fuel system previously drained for some reason? What method have you been using to try to start the engine? Les. Quote Link to comment Share on other sites More sharing options...
disco tom Posted April 16, 2010 Author Share Posted April 16, 2010 not that i am aware of a fuel drain, to start i have filled fuel filter to brim and primed on lift pump and spun engine over with injector pipe loose/off thanks for replying Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 16, 2010 Share Posted April 16, 2010 To get the fuel from 'one side of the pump to the other' requires more cranking than most batteries can deliver without going flat. The best way to get a diesel engine running that is 'dry' is to tow start it. Les. Quote Link to comment Share on other sites More sharing options...
