jasonf Posted April 17, 2010 Share Posted April 17, 2010 hi i have just swapped out my old 110 5spd manual and fitted a 4 speed rr box which has gone in ok but now the rear propshaft is about 25mm too short! any ideas i am sure the box is in the right position ! thanks in advance jason Quote Link to comment Share on other sites More sharing options...
SeriousIIa Posted April 17, 2010 Share Posted April 17, 2010 The LT95 needs a 2 inch longer prop. So buy the correct one and you are done. Cheers BOwy Quote Link to comment Share on other sites More sharing options...
jasonf Posted April 17, 2010 Author Share Posted April 17, 2010 thanks for that how long and where can i get one from thanks again jas Quote Link to comment Share on other sites More sharing options...
101sean Posted April 17, 2010 Share Posted April 17, 2010 Not got access to parts book at the mo but you need a prop for an early 83 to 85 ish V8 110 Quote Link to comment Share on other sites More sharing options...
KKMobile Posted April 17, 2010 Share Posted April 17, 2010 Not sure what size it is you want, But if you give driveline a call with measurement from flange to flange he will make one for you Quote Link to comment Share on other sites More sharing options...
