Pacey Posted April 17, 2010 Share Posted April 17, 2010 Hi Guys Looking for a pressure washer, got a budget of about £300-400 tops. What do people recommend for keeping a defender clean, not looking for fancy gadgets but not looking to strip the waxoyl off either, just something that is going to deal with stubborn chassis mud etc. Thanks Quote Link to comment Share on other sites More sharing options...
jbs Posted April 17, 2010 Share Posted April 17, 2010 Karcher?-B+Q etc Quote Link to comment Share on other sites More sharing options...
Pacey Posted April 17, 2010 Author Share Posted April 17, 2010 I looked at them, but the further you go up the money range they seem to comes with lots of extras and very little power increase, but then i'm not sure how much power you actually need in the first place is a 100bar and 300lt/per min ok or is more needed? Quote Link to comment Share on other sites More sharing options...
white90 Posted April 17, 2010 Share Posted April 17, 2010 Massive pressure isn't what you need unless you want to remove the paint try and find a Steam cleaner they are a million miles away from cold pressure washers you will have to look for secondhand/refurbished I would save and wait rather than buy another cold washer. Quote Link to comment Share on other sites More sharing options...
Pacey Posted April 17, 2010 Author Share Posted April 17, 2010 Ahh like the sound of that, used steam before but hired the unit. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 17, 2010 Share Posted April 17, 2010 is a 100bar and 300lt/per min ok or is more needed? 300 litres a minute at 100 bar will take the panels off, never mind the paint I think you may have read the wrong line in the spec, either that or you were looking at a Heathrow fire monitor or something Most of the Karcher domestic ones are 100-120 bar and 10-15 litres per minute. I have a Karcher which has a spinning rotary head on, which is quite effective. Sounds a bit like a V-1 flying bomb too, which is cool Don't bother with the really cheap sub £50 ones, you could pee harder and they don't seem to last. If possible get one that switches off automatically when you release the trigger, as the cheaper ones don't and will overheat if you leave the pump running for long. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 17, 2010 Share Posted April 17, 2010 If I had your sort of budget I think I'd be after one of these.... http://www.amazon.co.uk/K%C3%84RCHER-K6-85M-Pressure-Washer-2500W/dp/B0001I1MT4 Quote Link to comment Share on other sites More sharing options...
Pacey Posted April 17, 2010 Author Share Posted April 17, 2010 Whats wrong with 300lt a minute lol, yes I meant an hour. Thanks for the advice, seen that Karcher do a domestic/semi-pro range of steam cleaners around the £700 mark so might save up for one of those bad boys. Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted April 17, 2010 Share Posted April 17, 2010 We have a steam/hot water industrial jetwash thing at work. It's the dogs - cruddy mud/oil covered series gearbox (original, so 30 years of muck) to looking like it's just been refurb'd in under 5 mins. I'd definitely be after one of these if I had some spare cash floating around. Quote Link to comment Share on other sites More sharing options...
Pacey Posted April 18, 2010 Author Share Posted April 18, 2010 Would this be any good if i stretched the budget and saved? http://www.machinemart.co.uk/shop/product/details/karcher-k855-hs-domestic-hot-water-pressure-wa Quote Link to comment Share on other sites More sharing options...
western Posted April 18, 2010 Share Posted April 18, 2010 Mines a Stihl RE126K, had it 5 years from new, does a good job for my 110. Quote Link to comment Share on other sites More sharing options...
Kelly L Posted April 21, 2010 Share Posted April 21, 2010 If I had your sort of budget I think I'd be after one of these.... http://www.amazon.co.uk/K%C3%84RCHER-K6-85M-Pressure-Washer-2500W/dp/B0001I1MT4 Such a very amazing link! Thank you for the post. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted April 21, 2010 Share Posted April 21, 2010 Just a word of warning. Whatever you spend, make sure that the unit uses standard BSP fittings for the hose. I kmow most of the K-Archer lower price ones use a special type of hose fitting meaning you can only use their hoses with it and they are about £60 a pop and are very easily damaged. Get one with standard fittings and you can replace with hydraulic hose should you need a replacement and that will last forever. Quote Link to comment Share on other sites More sharing options...
JST Posted April 21, 2010 Share Posted April 21, 2010 i'll echo Tonys words, save and get a refurbished hot water or steam cleaner, much better and quicker to use. a HWPW halved the time to clean my truck after an event. Quote Link to comment Share on other sites More sharing options...
Tonky Posted April 21, 2010 Share Posted April 21, 2010 We have loads of jetters in work ranging from the one in the workshop for every day up to big Ultra High Pressure site machines for concrete demolition (38lts min @ 38000psi). Take the advice of getting a steam or hot wash. Beware of some of the B&Q machines they are specially made for the market and spares are difficult and they are designed for washing the car and patio occasionally. Go to one of the specialist suppliers or Farm machine suppliers and they have small reliable profesional machines for not that much more than your budget. The one in our worshop is an EDGE LYNX is used nearly every day and is 5 yrs old without any problems, I think it was about £950.00 new but you can get refurbs. Try to get at least 100lts min @90ºC.and as said previous make sure it has bsp fittings on the hoses and lance. Quote Link to comment Share on other sites More sharing options...
