trickydicky Posted April 17, 2010 Share Posted April 17, 2010 hi i went for a drive today and noticed that there was a judder when going up hills it seemed to be from the backend has anybody got any ideas . it has a new prop the diff seems ok i fitted new bearings . it is a big rumble you can feel it through the car . the gearbox changes smoothly and the transfer box engages ok . the judder stops when you pull off the gas . P.S the engine seems fine Quote Link to comment Share on other sites More sharing options...
martifers Posted April 17, 2010 Share Posted April 17, 2010 Try taking the rear prop off and run in difflock to isolate the rear diff from power delivery. If still making noise, try taking rear shafts out to completely isolate it. Are you running a significant lift? What tyres are you running? Wheel balance check recently? How are the exhaust hangers? Quote Link to comment Share on other sites More sharing options...
bm52 Posted April 17, 2010 Share Posted April 17, 2010 i had a similar problem a few weeks a go - i was convinced it was the rear diff etc. it turned out to be my o/s/r inner wheel bearing. i put on 2 new bearing and everything was smooth and silent again. Quote Link to comment Share on other sites More sharing options...
snagglebag Posted April 17, 2010 Share Posted April 17, 2010 i 2nd that as i too found the same prob, why o why is it always o/s/r???? Quote Link to comment Share on other sites More sharing options...
KKMobile Posted April 17, 2010 Share Posted April 17, 2010 i had a similar problem a few weeks a go - i was convinced it was the rear diff etc. it turned out to be my o/s/r inner wheel bearing. i put on 2 new bearing and everything was smooth and silent again. He's already fitted new bearings Quote Link to comment Share on other sites More sharing options...
bm52 Posted April 17, 2010 Share Posted April 17, 2010 He's already fitted new bearings so he did.... doh! Quote Link to comment Share on other sites More sharing options...
trickydicky Posted April 17, 2010 Author Share Posted April 17, 2010 so he did.... doh! i think taking the rear shafts out sounds like a plan . the other thing is when you dip the clutch everything feels smooth wich makes me think gearbox or transfer box problem but i dont know much about them to be honest so any help would be great Quote Link to comment Share on other sites More sharing options...
trickydicky Posted April 19, 2010 Author Share Posted April 19, 2010 Try taking the rear prop off and run in difflock to isolate the rear diff from power delivery. If still making noise, try taking rear shafts out to completely isolate it. Are you running a significant lift? What tyres are you running? Wheel balance check recently? How are the exhaust hangers? i took the front prop off today and the juddery rumble stopped so im pretty sure its the front end . is there anyway of telling whats gone (diff or cv joints) ? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 19, 2010 Share Posted April 19, 2010 what condition are the UJs on the prop in? they could be past it. Is the truck lifted at all? Quote Link to comment Share on other sites More sharing options...
JST Posted April 19, 2010 Share Posted April 19, 2010 i would suggest front UJs as above Quote Link to comment Share on other sites More sharing options...
trickydicky Posted April 19, 2010 Author Share Posted April 19, 2010 what condition are the UJs on the prop in? they could be past it. Is the truck lifted at all? ujs not shocking but they are showing sighns of wear and the 90 is totaly standerd Quote Link to comment Share on other sites More sharing options...
martifers Posted April 20, 2010 Share Posted April 20, 2010 What's the nose bearing like on the front diff, signs of much wear? or output on transfer box? Quote Link to comment Share on other sites More sharing options...
Guppy Posted April 21, 2010 Share Posted April 21, 2010 My bet would be the front prop. I had a significant rumble in mine last year - symptoms as you describe but with the exception that mine had very recently undergone a front axle overhaul (new diff, and complete rebuild of hubs). I bit the bullet and boshed a new front prop in there. The rumble disappeared. Could be knackered UJ's - seized sliding joint or indeed your prop balance weights may have just fallen off! Quote Link to comment Share on other sites More sharing options...
