Puffernutter Posted April 18, 2010 Share Posted April 18, 2010 Or too cool as the case may be! I spent the afternoon fitting a pucker Kenlowe fan to my 110 (200Tdi). This is in place of the thermostatic fan (now removed) and I also removed the cowling. I took the car out for a spin to Salisbury Plain and the temperature gauge ended up at the same place as usual (fractionally above midway), but without the fan kicking in. I know that I wasn't pushing it, nor towing today, but is it reasonable to expect that just a natural airflow through the radiator is enough to keep the engine cool? My reason for fitting the electric fan was that as I have a veggie conversion, I want to speed up the time that the engine warms up (and thus use less diesel before it changes). I wasn't sure I was expecting just the "ram" air effect to cool the engine sufficiently! The question I am coming to, is - Is that too be expected, or is my thermostat playing up (although only about 5 months old) Cheers Peter Quote Link to comment Share on other sites More sharing options...
ian_s Posted April 18, 2010 Share Posted April 18, 2010 the 200tdi in my series doesnt have any fan fitted at all at the moment and doesnt get too hot, even when i push it much harder than i should. any time you are moving at much more than a fast walking pace, you should be getting enough cooling from the ram air effect, unless you are towing something effing heavy. Ian Quote Link to comment Share on other sites More sharing options...
jbs Posted April 18, 2010 Share Posted April 18, 2010 I run an Mondeo electric fan after seeing a thread on here by jwcooper, However I very rarely use it as even when driving along the engine stays cool all on it's own Quote Link to comment Share on other sites More sharing options...
western Posted April 18, 2010 Share Posted April 18, 2010 Tdi's run cool anyway even with the standard viscous fan fitted. standard stat should be a 88 degree. Quote Link to comment Share on other sites More sharing options...
Drizz Posted April 18, 2010 Share Posted April 18, 2010 my 300tdi temp needle hardly moved, towing another 300tdi up a steep hill maxing out at 30mph! Quote Link to comment Share on other sites More sharing options...
Puffernutter Posted April 18, 2010 Author Share Posted April 18, 2010 All, thanks for the quick replies. looks like I'm OK then! I'll be interested to see if it warms up any quicker without the old fan fitted. Next job on the list - fit a PTO winch. That means my crankshaft driven capstan winch should be appearing in the "For Sale" fairly soon. Cheers Peter Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted April 19, 2010 Share Posted April 19, 2010 My 200Tdi 90 hasn't ever had the fan come on while road driving yet, since fitting it in 2008! Comes on off-road, but there's less airflow then so that's what I would expect. Bear in mind Land Rover designed it to work in the hottest or coldest climates around, so the paltry British 'heat' is nothing to such an over-compensated system Quote Link to comment Share on other sites More sharing options...
