landroversforever Posted April 19, 2010 Share Posted April 19, 2010 I think after this episode with the wheelnuts, and needing to change the pinion seal. I need a torque wrench. I'm looking at the halfords ones, But I'm unsure as to which range will be better? 8-60Nm or 40-200Nm Or in old money: 6-45 lb.ft 30-150lb.ft Quote Link to comment Share on other sites More sharing options...
errol209 Posted April 19, 2010 Share Posted April 19, 2010 I think after this episode with the wheelnuts, and needing to change the pinion seal. I need a torque wrench. I'm looking at the halfords ones, But I'm unsure as to which range will be better? 8-60Nm or 40-200Nm Or in old money: 6-45 lb.ft 30-150lb.ft You'll generally need the big one, but some things need the smaller one! I have two Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 19, 2010 Author Share Posted April 19, 2010 I'll get the biggun for now then, and invest in the smaller one at a later date Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted April 19, 2010 Share Posted April 19, 2010 Definitely get the big one first, its the one you'll use most. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 20, 2010 Share Posted April 20, 2010 I have both Halfords Pro wrenches. You are more likely to round off/strip/shear a lower torque bolt than a higher one in my opinion, so buy both if you can. Les. Quote Link to comment Share on other sites More sharing options...
missingsid Posted April 20, 2010 Share Posted April 20, 2010 I first bought the largest Halfords one, then took it back and bought the small and middle ones as the largest is too big for 90% of jobs even on a LR. I was using it to replace the heads on a V8 and even then it would only suit one job, the head bolts. Good quality and lifetime garuntee but poor cases, they will break if knocked hard and no packing inside to protect it. Marc. Quote Link to comment Share on other sites More sharing options...
freeagent Posted April 20, 2010 Share Posted April 20, 2010 i've got the 40-200NM one from Halfords - a great tool and will do most applications on your 'Rover. Quote Link to comment Share on other sites More sharing options...
