swaged holes in ali
ibexman
If you mean a flaring or belling tool then you need to get hold of a book by Ron and sue Fournier titled as the metal fabricators handbook-I got mine off of e-bay, It's really good It's also show's you how to make a roll cage too however after looking at pirate 4x4 website I'd rather work off of his workings as I find them better explained
HTH
John
If you have access to a lathe then you can turn a die and anvil that can be pulled together with a bolt through the centre to make the swage.
make sure the die and anvil have a flat unformed anulus around the edge to keep the material flat when the swage is made.
