faulty fuel gauge
Hello,
Had some trouble with the fuel guage as it was always reading full, was told to change the guage which I did and I also changed the fuel pump as it was playing up but it still reads full and the only way to keep a check on the fuel level is with the trip and fuel light.
Theres only 3 wires from the pump and thought I had put them on the wrong way but it still dont work after changing them around.
Driving me mad.
Cheers
the 3 wires at sender unit are
fuel gauge -- green/blue
low fuel ight -- white/slate
earth -- black
at the fuel gauge
12v ign controlled feed -- green
from tank sender unit -- green/blue
earth -- black
with the fuel gauge showing full all the time, the problem could be a short to earth with the grren/blue wire.
gauge illumination -- red/white
