will4x4 Posted April 22, 2010 Share Posted April 22, 2010 Hi i changed my king pins and forgot to the swival housing seal..... very annoying. its now got worse and is leaking quite a bit. as a quick change is it possible to pull the cv / shaft out and then undo the bolts around the axle caseing and put the seal on from behind? I think it will work in theory just dont really want to do a complete strip down again..? thanks Will Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted April 22, 2010 Share Posted April 22, 2010 Can do that, or you can do the 'bodge' in the tech archive, which consists of cutting the seal and re-gluing it at the top Quote Link to comment Share on other sites More sharing options...
will4x4 Posted April 22, 2010 Author Share Posted April 22, 2010 the bodge sounds better i can imagine how you do but cant find the link do you have it? thanks ill go buy a seal then Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 22, 2010 Share Posted April 22, 2010 http://forums.lr4x4.com/index.php?showtopic=7305 Les. Quote Link to comment Share on other sites More sharing options...
shanghai1979 Posted April 22, 2010 Share Posted April 22, 2010 Are they filled with EP80 or one shot grease? Land rover couldn't stop them leaking so they changed to grease. Quote Link to comment Share on other sites More sharing options...
