Niamh Posted April 22, 2010 Share Posted April 22, 2010 What does one do, just pull and plug the vacuum pipe from the valve? It won't upset the EDC at all? Niamh Quote Link to comment Share on other sites More sharing options...
Richard Mills Posted April 22, 2010 Share Posted April 22, 2010 Hi There. I just made a tin gaskit the same as the one from the EGR to the pipe, but with no hole in it. The EGR can do what it pleases, but it gives no trouble now. Quote Link to comment Share on other sites More sharing options...
Niamh Posted April 23, 2010 Author Share Posted April 23, 2010 So you left the EGR valve in place then? Niamh Quote Link to comment Share on other sites More sharing options...
Bobbin Posted April 23, 2010 Share Posted April 23, 2010 Thats just what i did on both my disco's (300 tdi).Unbolt the steel flexi pipe that goes to the top inlet pipe & make a blank from a piece of steel sheet or similar.Refit & bolt up.EGR may still operate but no nasty gasses getting through.I must say in both my trucks i had to remove inlet manifold & clean out as both were crudded up ,one so bad there was only a 25mm hole visiable once hose removed.Well worth it with noticeable difference afterwards Quote Link to comment Share on other sites More sharing options...
Guest MRPLEBBY Posted April 23, 2010 Share Posted April 23, 2010 I have a td5 what difference soes this make when removed? Quote Link to comment Share on other sites More sharing options...
Niamh Posted April 25, 2010 Author Share Posted April 25, 2010 The more I read the more confused I get! Out there on the net there's talk about having to adjust the EDC pump timing when removing EGR. Is there any clear information anywhere at all? Niamh Quote Link to comment Share on other sites More sharing options...
karlo Posted April 25, 2010 Share Posted April 25, 2010 This is what you need for a 300TDI EGR Removal Kit No need to do any thing else except blank off the vacuum hose or disconnect the plug on later cars. Quote Link to comment Share on other sites More sharing options...
