georgy Posted April 22, 2010 Share Posted April 22, 2010 Has any one done any repairs to one or have any info on then I think that there must be bearings in them for the output shafts and think mine has collapsed and am wondering if I can do the repairs on it. Quote Link to comment Share on other sites More sharing options...
Llanigraham Posted April 23, 2010 Share Posted April 23, 2010 Why do you think the bearings have gone? Quote Link to comment Share on other sites More sharing options...
georgy Posted April 23, 2010 Author Share Posted April 23, 2010 Because there is exssesive movement in the end of the drive shaft (off side) and oil has leaked from both oil seals (near side shaft has no movement. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 24, 2010 Share Posted April 24, 2010 You can remove the diff as a seperate unit, then rebuild it on the bench to a reasonable standard. The output bearings are actually needle rollers and it's rare that these fail. Early Freelander diffs were very weak, and inner bearing (usually the pinion bearings), were prone to failure. How to get the diff off - http://forums.lr4x4.com/index.php?showtopic=36379 Les. Quote Link to comment Share on other sites More sharing options...
georgy Posted April 24, 2010 Author Share Posted April 24, 2010 You can remove the diff as a seperate unit, then rebuild it on the bench to a reasonable standard. The output bearings are actually needle rollers and it's rare that these fail. Early Freelander diffs were very weak, and inner bearing (usually the pinion bearings), were prone to failure. How to get the diff off - http://forums.lr4x4.com/index.php?showtopic=36379 Les. Thanks It is an early one 1999 I have removed the cover plate from it in situ and the play does appear to be on the inner bearing as I can see the movement when I push on the driveshaft I hope to get the unit off next week,But was hopeing some one would have info on setting up the axle when I rebuild it ie torqe settings and preload settings I havent worked on one for about 30 years (when Haynes Manuals gave info like that) Quote Link to comment Share on other sites More sharing options...
