jaysjetski Posted April 22, 2010 Share Posted April 22, 2010 As above, i have replaced the clutch as it was worn to the rivets. have fitted a new slave/master cylinder and mounting plate. the pedal is still on the floor. any ideas what could be the problem???? thanks Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 22, 2010 Share Posted April 22, 2010 Actuating rod seized in the side of the gearbox? This happened on mine as it had been stood for years. Basically you need to find the bit that isn't moving. Quote Link to comment Share on other sites More sharing options...
jaysjetski Posted April 22, 2010 Author Share Posted April 22, 2010 do you mean the clutch release fork? as this moves ok when the gearbox was removed to fit the clutch Quote Link to comment Share on other sites More sharing options...
jaysjetski Posted April 24, 2010 Author Share Posted April 24, 2010 Anything else i can look for???? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 26, 2010 Share Posted April 26, 2010 Yes, I meant the clutch release fork. Since there's not an awful lot to the system there's no great trick to finding the problem, just work through it until you find something that isn't behaving. Quote Link to comment Share on other sites More sharing options...
Bobs Posted July 11, 2010 Share Posted July 11, 2010 Did you ever resolve this? I too have similar problem Regards Quote Link to comment Share on other sites More sharing options...
jaysjetski Posted July 12, 2010 Author Share Posted July 12, 2010 ummm. to be honest it has seem to just get better since the clutch has aged a little. sorry Quote Link to comment Share on other sites More sharing options...
