Bobs Posted April 23, 2010 Share Posted April 23, 2010 Hi to change the vcu will i need to dismantle the uj's, or, with the props removed from the vehicle will there be sufficientspace to fit a spanner onto the bolts? Thanks in advance but I need to know how much time to allow for the job Quote Link to comment Share on other sites More sharing options...
v8bertha Posted April 23, 2010 Share Posted April 23, 2010 The UJ's do not need to be dismantled. Undo the bolts that hold the prop shaft ends into each end of the VCU. There is no need to remove them, just undo them enough to slide out the "U" shaped spacer. Then you can slide the prop off the VCU splines... I say slide... they may need a bit of gentle persuasion with LR special tool No.1! Quote Link to comment Share on other sites More sharing options...
potus Posted April 24, 2010 Share Posted April 24, 2010 You'll need to remove the props and VCU as one then as V8bertha says, remove the UJ end bolt and washer anf then if its anything like mine, a 3lb hammer and puller to shift! good luck Mike Quote Link to comment Share on other sites More sharing options...
