barmiebrumie Posted April 23, 2010 Share Posted April 23, 2010 Could any one tell me what is the 'normal' thickness for them ?, also waht is the normal length & width as just discovered some at work that I maybe able to have, Thanks in advance John Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted April 23, 2010 Share Posted April 23, 2010 Normal size is about 120cm x 30cm by 38mm. Some people use 50mm thickness but they are very heavy when full of mud. Quote Link to comment Share on other sites More sharing options...
barmiebrumie Posted April 24, 2010 Author Share Posted April 24, 2010 Normal size is about 120cm x 30cm by 38mm. Some people use 50mm thickness but they are very heavy when full of mud. Cheers, will measure them when back at work monday John Quote Link to comment Share on other sites More sharing options...
bobtail4x4 Posted April 24, 2010 Share Posted April 24, 2010 I dont like the way the thinner ones bend under load, but if they are free? Quote Link to comment Share on other sites More sharing options...
Guest Posted April 25, 2010 Share Posted April 25, 2010 I have a set of the 50mm ones, whilst it is true they are heavy, I use them for bridging (driving over) more than sand ladders, if I just wanted sand ladders I would go for a set of ali ones, I did have some 35mm ones but they were too thin and I began not to trust them which then removes the point of carrying them... I have also use mine as a ramp in the past when I damaged my engine guard and needed to get under and repair it a couple of big stumps and the boards resting on them and I was sorted. Jason Quote Link to comment Share on other sites More sharing options...
