Woody3 Posted April 24, 2010 Share Posted April 24, 2010 I'm trying to remove the electric seats out of a RRC but have no battery to enable them to move along the runners. I have removed the 2 front bolts from the seat subframe but I can't get to the ones at the rear. Is there anyway of turning something so that they roll forward on the runners? Thanks! Quote Link to comment Share on other sites More sharing options...
bishbosh Posted April 24, 2010 Share Posted April 24, 2010 I think the easiest way is finding your self a 12V power supply as the motors will be hard to get out without first taking the seat out. Can you not run a pair of jump leads from another vehicle to the battery terminals on the RRC? Quote Link to comment Share on other sites More sharing options...
Woody3 Posted April 24, 2010 Author Share Posted April 24, 2010 Ok thanks. I've done this, but I think the seat fuse is blown! Any idea where this is? I've found a fuse box to the left of the console but can't seem to see the icon for the elec. seats. It is a 1992 RRC Vogue SE. Thanks. Quote Link to comment Share on other sites More sharing options...
Woody3 Posted April 24, 2010 Author Share Posted April 24, 2010 All sorted now...ta Quote Link to comment Share on other sites More sharing options...
jasonf Posted April 25, 2010 Share Posted April 25, 2010 hi woody i have just done the same thing ,you don't happen to know the wiring on the connectors do you so i can adapt my defender to take them ta jas Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 25, 2010 Share Posted April 25, 2010 Seat fuses are under the passenger seat, behind the ABS ECU (assuming you have this), small black box Alternatively, the only power going to the seat is via a 3 pin connection under the passenger seat, unplug this and with trial and error you should be able to find which does what, of course there is always RAVE which would tell you what each pin does Quote Link to comment Share on other sites More sharing options...
