Disco II - Toroidal vertical tanks in boot
stuckinthemud
 Share
Has anyone done an LPG conversion, but rather than the normal under-slung tanks and smaller petrol tank, has placed 1 or 2 vertical toroidal tanks in place of the side boxes in the boot and retailed the full size petrol tank?
If so, any chance of some photos of how they fit in the boot?
I've currently got the under-slung tanks, but vehicle range with 80L of LPG (about 55L actual) and 20L of petrol is not that great, so considering a pair of 80L tanks in the boot and going back to the full size petrol tank.
Jim
I have not seen any conversion like you describe. I would check you can get 80l vertical toroidal tanks with someone like Tinley Tech. The big under boot floor ones are only designed for horizontal use.
I can only imagine two vertical tanks would take up a lot of boot space. It may work out cheaper just to have one big cylinder in the boot, at the sacrifice of space of course :(
I can fully sympathise with your lack of range issues. I have four tanks in my RRC totalling 100 litres. Gives for a reasonable range.
 Share
