tweetyduck Posted April 25, 2010 Share Posted April 25, 2010 does the rear stub axle on a 110 detach from the axle itself. It looks like its part of the whole rear axle. TA Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 25, 2010 Share Posted April 25, 2010 Yes it does come off - undo the 7 x bolts that hold it to the axle tube and if necessary - give it a clout with a mallet or similar. Les. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted April 25, 2010 Share Posted April 25, 2010 Sometimes something a little more substantial than a clout is required Mo Quote Link to comment Share on other sites More sharing options...
Guest noggy Posted April 25, 2010 Share Posted April 25, 2010 Yes it does come off - undo the 7 x bolts that hold it to the axle tube and if necessary - give it a clout with a mallet or similar. Les. Where is the 7th bolt? Quote Link to comment Share on other sites More sharing options...
western Posted April 25, 2010 Share Posted April 25, 2010 Where is the 7th bolt? there's only 6 on a 90/110 rear stub axle, IIRC 7 on a Series LR. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted April 25, 2010 Author Share Posted April 25, 2010 thanks guys. I'm scared.....already clouted it more than i would. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 25, 2010 Share Posted April 25, 2010 The 7th bolt is only on the SAS models Les. Quote Link to comment Share on other sites More sharing options...
errol209 Posted April 25, 2010 Share Posted April 25, 2010 thanks guys. I'm scared.....already clouted it more than i would. [obi] ... just use the force* young Neill... [/obi] *Big hammers theory of Engineering: Hit it If it doesn't shift, get a bigger hammer and repeat from 1. If it breaks, well you needed a new one anyway Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted April 25, 2010 Author Share Posted April 25, 2010 Thanks all for the encouragement. If i might ask, why would i want to remove it anyhow? I'm meant to be replacing the brake disk and pads a wheel bearings and seal. What would i need to remove the stub for? Theres nothing amis this is just maintenance. So before I put it all back together can you give me a good reason to get out the BIG hammer... Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 25, 2010 Share Posted April 25, 2010 Unless you have a leak behind it or the stub needs replacing, then there's no need to remove it. Les. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted April 25, 2010 Author Share Posted April 25, 2010 Thanks Les. I'll give it a miss then. Super. Quote Link to comment Share on other sites More sharing options...
