bobed90 Posted April 26, 2010 Share Posted April 26, 2010 I am curently rebuilding the rear axle on the works 110 which has been fitted with a range rover 10 spline rear axle ( which is why i am posting in this section) The bearings had collapsed and severly damaged the stub axle and hub. Im in the process of fitting a second hand hub, but the bolt holes used to secure it to the brake disk are full of carp and i cant get the bolts to do up. Can someone tell me what the correct thread size is so i can get a tap to clean out the threads before i end up snapping a bolt in it. Im not at work till tomorrow so was planning on ordering a new tap and die set so want to make sure the right size bit will be in the set i get. Thanks Jason Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 26, 2010 Share Posted April 26, 2010 Range rover axle on a 110.... Quote Link to comment Share on other sites More sharing options...
bobed90 Posted April 26, 2010 Author Share Posted April 26, 2010 I work at a driver experience centre, the vehicles never see the road or go over 30 miles per hour. They spend so much time in mud that the axles get through a lot of seals and bearings and occasionally diffs. The decision was made long before i started, to fit a standard rear axle to make changing the rear diffs easier and also so we can keep less parts in stock. We run 2 300tdi 110s and a 300 tdi disco, i have been there for only 2 weeks and the 4x4s take up much of my maintainance time. So far i have rebuilt 2 rear axles and a front axle, changed a water pump and a load of bushes and there is still loads more that needs doing in the near future . We also run a mercedes skid car, a chieftan tank, a tatra 8x8, bedford mj, renault 420 tractor unit with 45ft trailer, 16 ton 360 digger, and 6 rally cars. We also have a few 432 tanks kicking about and 7 alvis stalwarts, and i am responsible for the repairs on all of them and i also do the instucting on everything except the skid car. So im a little busy and all maintainance has to be done in a limited amount of time. But its fun, and so far i am enjoying the experience. Thanks Jason Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 26, 2010 Share Posted April 26, 2010 Ahhhh that makes sense now . Sound like fun! Would love to have a go in all of them! Quote Link to comment Share on other sites More sharing options...
Bille Posted April 26, 2010 Share Posted April 26, 2010 I am curently rebuilding the rear axle on the works 110 which has been fitted with a range rover 10 spline rear axle ( which is why i am posting in this section) The bearings had collapsed and severly damaged the stub axle and hub. Im in the process of fitting a second hand hub, but the bolt holes used to secure it to the brake disk are full of carp and i cant get the bolts to do up. Can someone tell me what the correct thread size is so i can get a tap to clean out the threads before i end up snapping a bolt in it. Im not at work till tomorrow so was planning on ordering a new tap and die set so want to make sure the right size bit will be in the set i get. Thanks Jason I had a similar bolt problem about 15 years ago, couldn't find out the size until I was told to take it down to the local Engine Re-builder, guy in the office just asked the Fitter and Turner to measure the sample bolt which he did and identified the thread and the pitch, they also offered to lend me their tap but someone had broken it and it hadn't been replaced, so he sent me down to the local supplier who provided me with the correct tap. Quote Link to comment Share on other sites More sharing options...
bobed90 Posted April 26, 2010 Author Share Posted April 26, 2010 Unfortunately i dont have the time to go around various places to sort the bolt size out. I need to have the axle fully reassembled by wednesday morning! Which is a simple enough task but i also have to fit a new exhaust to a double decker bus and fix an air leak on it and fix another air leak on the renault lorry, so i have a very busy day tomorrow ! No doubt the landrover will be back in the workshop by wednesday afternoon anyway, as im taking a group of 11-16 year olds out for there first drive offroad aspart of a government education program. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted April 26, 2010 Share Posted April 26, 2010 I only have parts data for Range Rover Classics from 1986 onwards, but it shows it as an M10 bolt, FTC1368. So it may be M10 Quote Link to comment Share on other sites More sharing options...
bobed90 Posted April 26, 2010 Author Share Posted April 26, 2010 Thanks for that, it looks like the right bolt. Any idea what the pitch of the thread is? Thanks Jason Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted April 26, 2010 Share Posted April 26, 2010 From memory on doing mine, I *think* they are M10 Coarse, so 1.5mm. But don't quote me on that Quote Link to comment Share on other sites More sharing options...
bobed90 Posted April 27, 2010 Author Share Posted April 27, 2010 Thanks again you were right, they are indeed M10 1.5 coarse thread. I have now fully rebuilt the axle and managed to test it earlier and all worked well. Thanks Jason Quote Link to comment Share on other sites More sharing options...
