jasonf Posted April 26, 2010 Share Posted April 26, 2010 hi all how much and what flavor does the lt95 auto box take ta Quote Link to comment Share on other sites More sharing options...
BeBobbed Posted April 26, 2010 Share Posted April 26, 2010 hi all how much and what flavor does the lt95 auto box take ta I think the LT95 is a manual box, 4 speed but I may be wrong. Is it the TF 727 box you've got? The early 3-Speed Auto or the ZF4Hp22 4 Speed? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 26, 2010 Share Posted April 26, 2010 LT95 is a manual box, so do you have an LT95 or an auto box? Quote Link to comment Share on other sites More sharing options...
jasonf Posted April 26, 2010 Author Share Posted April 26, 2010 its the rrc 4spd auto box have i got it wrong again! Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted April 26, 2010 Share Posted April 26, 2010 That's the ZF4Hp22. The workshop manual is out in the garage, but it takes standard automatic transmission fluid. Quote Link to comment Share on other sites More sharing options...
jasonf Posted April 27, 2010 Author Share Posted April 27, 2010 That's the ZF4Hp22. The workshop manual is out in the garage, but it takes standard automatic transmission fluid. thanks geoff do you know how much? Quote Link to comment Share on other sites More sharing options...
jonket Posted April 27, 2010 Share Posted April 27, 2010 The Haynes service and repair manual says 9.1 liters ( 16 Imp pints,20 US pints) of ATF Dexron IID. The RAVE manual agrees. But changing ATF fluid, there will be something left in the transmission. Just fill to MAX on dipstick. The Borg Warner transfer case uses also this ATF Dexron IID. From dry it needs 1.7 liters (IMP pints 3.0, US pints 3.6). Do not use gear oil. Quote Link to comment Share on other sites More sharing options...
