JST Posted April 27, 2010 Share Posted April 27, 2010 How do you tell what ratio a T box is if its not written on it? There was a post about it a few days back in another topic but i cant now find it! Quote Link to comment Share on other sites More sharing options...
reb78 Posted April 27, 2010 Share Posted April 27, 2010 Does the tech info here help? http://www.ashcroft-transmissions.co.uk/part_8.html#pa1 I think you can tell from the serial number according to this (unless someone has altered it - then i think it is a case of counting teeth on the input gears.....) Should be able to work out tooth numbers for each ratio from this: http://www.ashcroft-transmissions.co.uk/part_28.html Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted April 27, 2010 Share Posted April 27, 2010 James Bear in mind LR have number in 2 different places dependant on year . model 1 - on the back face of the box, Left Hand side bottom edge, looking from the back end at the Handbrake 2- and a pig to see, "Round the corner" of the above, so at the back and bottom edge of the passenger side of the casing <cough> and yes I know this for a reason Nige Quote Link to comment Share on other sites More sharing options...
