matthew74 Posted April 27, 2010 Share Posted April 27, 2010 My rear cross member could do with sprucing up. I've used smoothrite before on my previous 90 but thought it was too shiney. Is there any recommendations for spray paint that gives a similar finish to the original matt powder coated look. Cheers, Matt. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 28, 2010 Share Posted April 28, 2010 Stone chip is a good paint if applied properly. You can apply that as a protective coating for the crossmember itself, then overpaint with aerosol satin black. Les. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted April 28, 2010 Share Posted April 28, 2010 I was about to post the same - I've used hammerite stone chip in an aerosol. It goes on really well if you warm it up and has a nice factory look to it. Quote Link to comment Share on other sites More sharing options...
matthew74 Posted April 28, 2010 Author Share Posted April 28, 2010 Thanks Gents. Quote Link to comment Share on other sites More sharing options...
natas Posted April 28, 2010 Share Posted April 28, 2010 Thanks Gents. Dont know if this is availible in the UK? I was thinking of using it on the inside of the tub and the rear crossmember of my 90 truck cab. http://www.herculiner.com/index.html Quote Link to comment Share on other sites More sharing options...
Anderzander Posted April 28, 2010 Share Posted April 28, 2010 Apparently its sold under this name in the UK: protectakote.co.uk Quote Link to comment Share on other sites More sharing options...
