lacrits68 Posted April 30, 2010 Share Posted April 30, 2010 (edited) hello! When it was time for 1st service on my -97 110tdi i discovered this on one of the front wheels: how do i fix this...it see that chims and circlip has become one with the chaft. I assume that hamering is a "no-no"....any tips or ideas how to do? cheers Jan-one whos sad when people dont take care of they LR's Edited April 30, 2010 by lacrits68 Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 30, 2010 Share Posted April 30, 2010 Oh dear, front wheel? Someone has buggered it up The reason for welding it up is usually to bodge up any play there might have been between driveshaft and drive member. You won't be able to strip the hub in any way at all with it welded like that. To repair it - you will have to grind the weld off right back until the flange comes off, then replace the CV joint as you just ground off the end of it. New CV joint/drive member, 2 x shims, gasket, and circlip to fix it. Les. Quote Link to comment Share on other sites More sharing options...
lacrits68 Posted April 30, 2010 Author Share Posted April 30, 2010 Hello! Im no sure if its welded...bacause i found parts of circlip or chims in the "cup" protecting the hubb! there was alot of rust in the "Cup" when i removed it! can clearly see "round leftovers" in it! cheers Jan Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 30, 2010 Share Posted April 30, 2010 Clean off the rust and then undo the 5 x 17mm bolts. The drive flange should then come off. Looks pretty bad to me even if it's not been welded. Les. Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted April 30, 2010 Share Posted April 30, 2010 Good luck getting that off! From past experience of customers vehicles when things get that bad you usually have to resort to the gas axe or a grinder. I think you may be compiling a list of required new parts soon. Steve Quote Link to comment Share on other sites More sharing options...
KKMobile Posted April 30, 2010 Share Posted April 30, 2010 That don't look good Got some new Ashcroft flanges never fitted to fit a 110 if your interested?? when your sourcing parts?? Kev Quote Link to comment Share on other sites More sharing options...
lacrits68 Posted April 30, 2010 Author Share Posted April 30, 2010 hello! it seems that parts are "electricity glued"...! heres a pic of flange sanded and after some angelgrinding: sadly i cant separare them...getting p** off..! But you can see how worn flange has been before welding..! cheers Jan Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted April 30, 2010 Share Posted April 30, 2010 Looks to me like you'll have to grind the flange off totally aswell......................... Quote Link to comment Share on other sites More sharing options...
Ex Member Posted April 30, 2010 Share Posted April 30, 2010 Grind a bit more and hit the stub of the CV with a big hammer. It should be able to move in. Then new CV and drive flange. Don't you love previous owners. They could have just replaced the drive flange. They cost nothing.... Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 30, 2010 Share Posted April 30, 2010 I beg to differ - they are about a tenner Les. Quote Link to comment Share on other sites More sharing options...
lacrits68 Posted April 30, 2010 Author Share Posted April 30, 2010 Don't you love previous owners. They could have just replaced the drive flange. They cost nothing.... Yes I do! Fixed it myself...saved a quid! I rather keep my 110 as standars as possible cause "original" parts are easier to find when thay brake, rather that "custom/special" parts! Our 110 is used as "overland/adventure" car! last summer was "russia-with-rover" with discovery...110 was bought after that trip, cause we realized that disco 2 is too small for longer trips..! cheers Jan Quote Link to comment Share on other sites More sharing options...
lacrits68 Posted May 1, 2010 Author Share Posted May 1, 2010 VICTORY! and DEFEAT! quess how hubb internals looks like! Tried to loosen 1st lock nut with "hubb tool" not an mm/inch of movment! Soked it all in "rustoil" and hopefully tomorrow im more lucky! Othervice i borrow HD 52mm nut&vrench from work on monday! cheers Jan Quote Link to comment Share on other sites More sharing options...
dantd5 Posted May 2, 2010 Share Posted May 2, 2010 Holy Evander Holyfield!!!!! Quote Link to comment Share on other sites More sharing options...
