optixelectrics Posted May 1, 2010 Share Posted May 1, 2010 Hi Everyone, My Disco failed the mot on excessive play on the front nearside wheel bearing. It gave up completely on my way home from the MOT centre and tried to spit me in to the kerb! When I took it apart, the front bearing was still in fairly good condition, but the rear bearing fell out in little bits all over the drive. I had to cut the old bearing shell from the stub axle carrier, as it wouldn't budge. I have now got it replaced and refitted, but suspect the next time it goes it will need a new stub axle carrier. Have you got a part number please. It is KA on the chassis number on a 1993 S1 Disco 200TDi. All the bearings are the same. Does this apply to the front and rear stub axle carriers as well? Thanks Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 1, 2010 Share Posted May 1, 2010 Part number FTC3154 - from JA suffix - Disco 1 from 1994. Part number FTC57 up to suffix JA. Les. Quote Link to comment Share on other sites More sharing options...
optixelectrics Posted May 4, 2010 Author Share Posted May 4, 2010 Part number FTC3154 - from JA suffix - Disco 1 from 1994. Part number FTC57 up to suffix JA. Les. Thank you Les. I will get a couple of spares ordered now. Cheers, Myk Quote Link to comment Share on other sites More sharing options...
