Mike Brownlie Posted May 1, 2010 Share Posted May 1, 2010 Hi, Im changing my chassis on my 90 to a galvy one. I have ordered a full bush kit and wondered what else i should replace while im at it. What are the typical bolt sizes i will need when doing the swap. Thanks Mike Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 1, 2010 Share Posted May 1, 2010 You'll need a shed load of bolts, make friends with your local stockist. I recently bought, for a Series 3 88" that I'm converting to Metric stainless fittings where possible: M6 x 20mm through 60mm M8 x 20mm through 80mm M10 x 25mm through 80mm I got about 50 of each to start with, but am running out of some sizes. There are also plenty of other sizes of which you will only need a few. Bulkhead-to-chassis for example, M12 x 180 I believe. Bear in mind that some things will need to be high tensile, the bolts that hold on the axles for example, while a lot of others do now. The fixings holding the floors down, the roof up etc can be stainless. Generally a good guide is the part numbers, have a look at this site: http://www.ep90.com/index.php?id=28 From that you can work out what size a bolt is, and whether it needs to be high tensile. Hope that helps Quote Link to comment Share on other sites More sharing options...
Blippie Posted May 2, 2010 Share Posted May 2, 2010 Worth doing clutch if the engine and box is out .... Cheers Blippie Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted May 3, 2010 Share Posted May 3, 2010 Hi If you do a search you'll find loads of info as this is covered fairly regularly Mike Quote Link to comment Share on other sites More sharing options...
heath robinson Posted May 3, 2010 Share Posted May 3, 2010 Gearbox and engine mount rubbers, maybe brake pipes, and fuel lines. I'm having all the little brackety doo-hickeys galvanised by a local firm, for not a lot, and depending on how far you want to go, you could always galv the footwells etc. Have a look at Si Whites build thread for ideas. Jake Quote Link to comment Share on other sites More sharing options...
Mr Bean Posted May 3, 2010 Share Posted May 3, 2010 Bulkhead change? Quote Link to comment Share on other sites More sharing options...
nicks90 Posted May 4, 2010 Share Posted May 4, 2010 if you're stumping up the pennies for a new chassis - might as well chuck new brake pipes, fuel pipes and wiring loom at it as well. Quote Link to comment Share on other sites More sharing options...
