paul mc Posted May 1, 2010 Share Posted May 1, 2010 I had the heads off redoing gaskets, valves etc now i have the engine back together it will turn over but won't fire. Looking back through the Haynes manual i should have re-installed the distributor with the rotor arm just before cylinder one HT lead while cylinder 1 is at TDC of the compression stroke, but with the heads and all back together how can i tell if i'm on compression or exhaust stroke? Cheers Quote Link to comment Share on other sites More sharing options...
zim Posted May 2, 2010 Share Posted May 2, 2010 take your rocker cover off, turn the engine over and have a look to see what your valves are doing they will both be closed on compression or ... take your dizzy out, turn the crank one revolution back to tdc - and then put it back in. you will now be on a different stroke. G Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted May 2, 2010 Share Posted May 2, 2010 Take number one plug out, stick your thumb over the hole and turn the engine via the crank pulley nut - you can feel the compression - then keep turning until the timing markers line up Quote Link to comment Share on other sites More sharing options...
paul mc Posted May 2, 2010 Author Share Posted May 2, 2010 Take number one plug out, stick your thumb over the hole and turn the engine via the crank pulley nut - you can feel the compression - then keep turning until the timing markers line up Good idea, i was hoping for something like that which didn't involve taking bits off the engine again Quote Link to comment Share on other sites More sharing options...
GT6Steve Posted May 2, 2010 Share Posted May 2, 2010 I'll stick a piece of fuel line into the plug hole and blow to see if the cylinder will hold pressure, as in both valves closed. Quote Link to comment Share on other sites More sharing options...
meathumper Posted May 3, 2010 Share Posted May 3, 2010 I use the thumb trick, works every time. Quote Link to comment Share on other sites More sharing options...
