Tibout Posted May 2, 2010 Share Posted May 2, 2010 Hi there I've been advice by you guys to put ATF dexron iii in my gearbox but when i've been to several shops and they told me it's for automatic transmission! Could someone clarify me please thank you thierry Quote Link to comment Share on other sites More sharing options...
rovernut Posted May 2, 2010 Share Posted May 2, 2010 Hi there I've been advice by you guys to put ATF dexron iii in my gearbox but when i've been to several shops and they told me it's for automatic transmission! Could someone clarify me please thank you thierry LT77 Manual gearbox has ATF (Automatic transmission fluid). I think the reason is that there is an internal oil pump in the 77 and it cannot handle the thicker gearbox oils. Not sure about Dexron 111 without checking. Quote Link to comment Share on other sites More sharing options...
Jon White Posted May 2, 2010 Share Posted May 2, 2010 ATF is the correct oil for an LT77. If you dont beleive us look it up in your owners manual! Jon Quote Link to comment Share on other sites More sharing options...
Tibout Posted May 2, 2010 Author Share Posted May 2, 2010 Hi guys thanks for the advice it's not that I don't beleive you guys just a bit confuse!!! So any ATF will do for my lt77 ? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 2, 2010 Share Posted May 2, 2010 Dextron II or III I think is what's advised. Quote Link to comment Share on other sites More sharing options...
white90 Posted May 2, 2010 Share Posted May 2, 2010 Difflock sell it in bulk as do most LR factors. check the colour of yours though if still a good colour a change won't hurt but may be a job that can wait. Quote Link to comment Share on other sites More sharing options...
Tibout Posted May 2, 2010 Author Share Posted May 2, 2010 Thank you I've got ATF dexron iii Quote Link to comment Share on other sites More sharing options...
