rawsondsr Posted May 2, 2010 Share Posted May 2, 2010 the flash part on the headlight stalk no longer works? new stalk required, or something easier to fix it? '84 One Ten Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted May 2, 2010 Share Posted May 2, 2010 Might wasn't working until I took off the steering shroud and realised the wire had popped off. Also, check that the contacts touch each other when the stalk is moved (labelled B in the photo) Quote Link to comment Share on other sites More sharing options...
oap Posted May 2, 2010 Share Posted May 2, 2010 the flash part on the headlight stalk no longer works? new stalk required, or something easier to fix it? '84 One Ten Yeah its proberly the problem at least it was on mine. Its not a big job though, half an hour maybe but the switch was expensive from Landrover. Quote Link to comment Share on other sites More sharing options...
