1965 Posted May 11, 2006 Share Posted May 11, 2006 hello everyone i could do with some help if you don't mind . today i bought a series 3 lwb van that i've been looking for for months , and i'm desperate to start using it and get rid of my 90 and my disco and get back to a propper landrover , the problem is the engine is duff and it's a 2.6 6 cylinder ( oh dear ) . now here is the problem . what would be involved in swapping it for a 2.5 nad that i have sat in my back yard ie : will it bolt up to my 6 cyl gearbox and engine mounts . ( other suggestions welcome) i have big plans for this motor at some point in the future but they need to wait due to other projects . i need and want to start using it now . all help and advise will be welcome , thanks in advance . rick... Quote Link to comment Share on other sites More sharing options...
Tonk Posted May 12, 2006 Share Posted May 12, 2006 i believe the 6 cyl bellhousing is different than the 4 cylinder one, the 2.5NA will mate straight to the 4 cyl series bellhousing. no idea about your engine mounts though its not hard to chop them off and remake Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 12, 2006 Share Posted May 12, 2006 Tonk's right - the 6cyl bellhousing and engine mounts are different although I believe the gearbox is still the same (EG you should be able to just swap bellhousings but don't quote me on this). The whole engine & box are further back in the chassis, which shouldn't be a problem but it's worth remembering. If you have a 4-pot sat round then that's a good option, if not then consider a V8 - it's more powerful and more economical than the 6 and a lot cheaper to replace/repair, and although the conversion is a bit of work it's not rocket science. A 3.5 EFi will see you getting 20mpg if you're well behaved which makes a 4-pot seem like a less attractive option. Whichever way you go there will be plumbing issues - rad hoses and fuel pump spring to mind, the 6 has a decent electric lift pump (will plumb straight into a V8) whereas the 4pot I think has a mechanical pump on the engine. Search back on this forum for 6pot -> V8 info, it's been asked and answered a few times. Edit: Check the classifieds: Clicky. This seems like a good price and the 6-pot conversion rings appear on eBay for about £40, in fact you might find someone who will swap it for your 4-pot one (I know a couple of people who have bought the wrong ones and had to change ) Quote Link to comment Share on other sites More sharing options...
1965 Posted May 12, 2006 Author Share Posted May 12, 2006 thanks for all the info , i've just been told there maybe a 2.25 engine and box for sale local so i may just put that in for now , at least i can use it then . i'll also check if thats right about the bell housing swap ,that would be even quicker . i plan put a 200 tdi in it later ( i've got one with auto box in a scrapper ) but thats been earmark for someone else . ( dam) . thanks again , and if anybodys knows if the gearbox is the same could they let me know . Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted May 12, 2006 Share Posted May 12, 2006 thanks for all the info , i've just been told there maybe a 2.25 engine and box for sale local so i may just put that in for now , at least i can use it then . i'll also check if thats right about the bell housing swap ,that would be even quicker . i plan put a 200 tdi in it later ( i've got one with auto box in a scrapper ) but thats been earmark for someone else . ( dam) . thanks again , and if anybodys knows if the gearbox is the same could they let me know . Yes the bellhousings will interchange, the 2.5 will be a better bet than the 2.25 as it is a good bit better in the torque department and slightly up on BHP as well. Oh and the rad will need changing as the fittings are in the wrong position on a 6 pot rad when it is coupled to a 4 pot. Quote Link to comment Share on other sites More sharing options...
1965 Posted May 12, 2006 Author Share Posted May 12, 2006 cheers phil , thats good news about the bellhousing , got the 2.5 nad radiater from my 90 ( it's the vehicle the engine came out off ) . so i guess all i need now is engine mounts ( and someone who can weld better than me to put them on ) . thanks for all the help i thought i'd made a mistake buying one with a 2.6 but i could'nt resist . cheers people ... Quote Link to comment Share on other sites More sharing options...
