will a td5 bonnet fit a c reg 90
Not sure about fouling - not a problem on a 98 so can't see why it would foul on an earlier one. I have a Puma bonnet on a 1990 Defender too.
The one major difference is the bonnet prop. The easy solution is to convert to the later prop and brackets. To fit the earlier scissor or stick type props will require some modifications to the bonnet.
 Share
