lowlandbear Posted May 3, 2010 Share Posted May 3, 2010 I have a 1974 light weight with a 2.25L diesel and a Lucas CAV injector pump. It was puffing diesel smoke and so I replaced the four injectors, now it smokes more and makes a loud noise. I think it is getting to much fuel and or the timing is off, but I cannot figure out how to set the timing or control the fuel mixture. Does anyone have documantation? Here are a couple of pictures of the pump. Thank you in advance, James Quote Link to comment Share on other sites More sharing options...
PeterW Posted May 3, 2010 Share Posted May 3, 2010 I have a 1974 light weight with a 2.25L diesel and a Lucas CAV injector pump. It was puffing diesel smoke and so I replaced the four injectors, now it smokes more and makes a loud noise. I think it is getting to much fuel and or the timing is off, but I cannot figure out how to set the timing or control the fuel mixture. Does anyone have documantation? Here are a couple of pictures of the pump. Thank you in advance, James James Unless I'm mistaken, thats not a Landrover engine ! The 2.25 CAV is an upright rotary pump with no solenoid cutoff, that looks like a very different beast. Got a pic of the engine, or the engine number..? Cheers Pete Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted May 4, 2010 Share Posted May 4, 2010 I think that may be a 2.5 N/A. A 2.25 though it certainly isn't! Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted May 5, 2010 Share Posted May 5, 2010 Thats a 12J 2.5nad pump and timing case. Quote Link to comment Share on other sites More sharing options...
errol209 Posted May 6, 2010 Share Posted May 6, 2010 Does anyone have documantation? The workshop manual covering the 2.5NAD diesel is in the Technical Archive, here, and a guide to doing the timing is here. Quote Link to comment Share on other sites More sharing options...
